Are there any activities not recommended with braces?
Just wondering if there's anything you just can't do with braces on.... I play soccer and I want to take show jumping up again this summer and I was wondering if that puts my braces at risk.... Maybe I would have to wear a mouthguard?
Smiling is in!
Tine
Tine
Yeah I think you are fine with most things.
You obviously can't get a properly fitted mouthguard with braces though, because each time your teeth move it will no longer fit.
I play softball and was given a loose fitting mouthguard which was so uncomfortable I never bothered with it. The main issue you have is your lips ending up cut, because your braces will keep your teeth in.
![Image](http://tickers.TickerFactory.com/ezt/d/4;29;2/st/20030702/e/braces+were+put+on/dt/16/k/686f/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10725;127/st/20060515/e/Debanding%21+%3A%29/dt/14/k/6fc0/event.png)
When I was a teenager (back in the dark ages), a boy in my class had to wear headgear to school every day. One day he got hit square in the face with a basketball.
It wasn't a pretty sight. I can't think of anything I wouldn't try with braces - if I had a good mouth guard.
Chris
![Surprised :o](./images/smilies/icon_surprised.gif)
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
Chris
![Image](http://tickers.TickerFactory.com/ezt/d/4;10728;114/st/20070503/e/Popcorn+Freedom+Day/k/b94b/event.png)
