twisted wire around brackets
Locked
MusicIsMyLife
#1 Post by MusicIsMyLife »
My ortho put wires (one on each side) that he wrapped around a bracket, braided it, then wrapped around the next bracket. He did this around my premolars on each side of my upper arch. I was wondering what this is for?
You can see it behind my regular wire in this pic:
Braced Sep. 29 '05
Tongue crib inserted Oct. 6
Tongue crib removed April 5
Estimated treatment time: 20 mths
johnnys_angel
#2 Post by johnnys_angel »
I had something very similar to this, and my orthodontist explained (as he was putting it on) that it was pretty much like a powerchain, did the same job, only a wire instead of whatever material they normally use ;).
Chris
#3 Post by Chris »
I think it creates alittle more pressure for movement just like when they use wire ties instead of o-rings.
Top Braces June 2004
Bottom Braces November 2004
Debanded January 2007
MusicIsMyLife
#4 Post by MusicIsMyLife »
Thanks! :)
Braced Sep. 29 '05
Locked
