Cosmetic dentistry after braces?
I know immediately I'll be getting an implant for the the missing tooth I have between my canine and front tooth (it was growing in the roof of my mouth, and my dentist I had as a child said "you don't need that" and pulled it out). Once they open a gap, they'll put a "plastic tooth" in my braces to fill up the hole. So once I'm debraced, I'll going to run to get the implant the same day so I won't look like a hillbilly. Whitening the same day, too, and then one-by-one, tooth colored fillings for those molars in the back, but no big rush for that. I got braces so I wouldn't get veneers, no matter what happens, I think I'll be satisfied with the results
I got braces a year ago (still have them) I only have 1 more year left, so i get them off before high school!
So far, im happy with the results. My teeth are a lot straighter, so far. But my gums are somewhat puffy because they put the brackets too far up in some place![Sad :(](./images/smilies/icon_sad.gif)
but im good, lol
scottsdale dentist
but im good, lol
scottsdale dentist
Tooth bonding + repair
Bonding is a process to repair minor cosmetic defects in teeth. The bonding material can be contoured/shaped by a dentist and is cured or hardened with ultra-violet light. Then, final shaping and polishing can be done by your dentist. It's also worthwhile to mention that bonding material can be matched to the natural color of your teeth. So, if you plan to have any teeth whitening done, do it before your bonding work.
I had some bonding work done 10+ years ago and spent a few hundred dollars for 3 teeth (2 canines and 1 front tooth that was slightly chipped after braces.
Hope this helps.
Hope this helps.
Teeth bonding - stains and chipping
No problem with staining at all. Minor chipping at the bottom of one tooth, where the bonding material was pretty thin. I had my dentist smooth out bonding and match the contour of the adjacent teeth and have not seen any problems since then. It's been over 10 years since the original bonding was done and I am very happy with the results.
