How do you clean your retainer?
kittenpoint
Re: How do you clean your retainer?
#16 Post by kittenpoint »
I have two hawley retainers and my ortho said to just brush them with toothpaste and if I notice any buildup then to soak them in 1/2 water 1/2 vinegar for 10 minutes then brush normally. She said that denture cleaner or retainer cleaner is fine too but not to use anything with alcohol or to boil them. Also no peroxide because she wasn't sure if that could cause the acrylic to change colors and since mine are lime green and teal so they could possibly fade.
I just soaked my Invisalign in half peroxide half water then brushed and I never had a problem with buildup on those but again don't use alcohol for those either.
Invisalign Started - 2/12/2014
25/25U - 5 Attachments
25/25L - 7 Attachments + 2 Metal Buttons
Elastics Started - Bears - 4/3/2014 | Latex Problem - Switched to Latex Free Jellyfish - 8/7/2014
Attachments Removed - 1/5/2015
Elastics Finished 2/9/2015
Bonded Upper Retainer - 2/9/2015
Removable Hawley Retainers - 3/5/2015
Bengals1418
#17 Post by Bengals1418 »
I use a sonic cleaner for my braces
bliss4me
#18 Post by bliss4me »
I soak in dish soap every day, and soak in baking soda a couple times/week.
Ashleyretainergirl
#19 Post by Ashleyretainergirl »
I use Dawn dish washing soap and it works great! They come out bright and shiny! We use Dawn to clean our forks and knives and those go into your mouth, so it makes sense to use it to clean off all the germs and food from your retainers too!
mysticgirl916
#20 Post by mysticgirl916 »
I have an Essix retainer on my top teeth, and my hygenist suggested just using soap and warm water with a soft-bristled toothbrush. I've also experimented with alcohol-free mouthwash like Listerine Zero, it works pretty good and it also gets the odors out of it
