Will it get tighter?
BrandiJeane
#1 Post by BrandiJeane »
I just got my retainer Nov. 15th and it feels a bit loose. I havent had any trouble with it bothering me or anything!
Brandi- 20
Started my braces journey 5/05!
Bex
#2 Post by Bex »
It's not normally too much of a problem if it's loose-as long as it's not falling out! Your Orthodontist can easily tighten it up if you pop back to see him!
Hope it helps!!
XxXxXx
