Loose teeth after brace removed
littletree
#1 Post by littletree »
my lower 4 front teeth feel loose after removal of braces? i can see slight movement when i touch them and is a bit scary ... i dont even dare to bite on them at all. understand that need sometime for the teeth to settle but how long? it it normal? help!!! :(
calypsojunky
#2 Post by calypsojunky »
I had that fear too, especially since one of my front tooth was erupted to match the length of the other. After a couple of months, the loosening has lessened, and I feel much more confident biting into food.
