Retainers as noticeable as braces?
michael33
#1 Post by michael33 »
When the retainer is put in, is the front wire at the same height on the teeth as regular braces would be or does it sit higher than braces? Is it less or more noticeable than braces?
Naked soon!
platinum
#2 Post by platinum »
It looks crap. I have¨now a Hawley retainer on my top. There is no way I will take Hawley when I will get my retainer.
michael33
#3 Post by michael33 »
platinum wrote:It looks crap. I have¨now a Hawley retainer on my top. There is no way I will take Hawley when I will get my retainer.
Not sure what that meant?
jennielee81
#4 Post by jennielee81 »
Platinum has a hawley retainer as a bite block right now. She will get her upper braces soon...then when all is done she will have retention with some sort of retainer. She's hoping NOT hawleys.
My hawley shows almost as much as my braces did. The wire is just about at the same place it was with my braces. But for some reason, people are less "interrested" in retainers than they were in braces.
Go figure> :wink:
serendipity
#5 Post by serendipity »
To wear I'm not sure what Hawleys are like as I have Essix retainers but I can say that Hawleys are alot more noticeable. Either way if they do there job thats the most important thing.
~serendipity
"Welcome to wherever you are - this is your life, you've made it this far..."
In Braces for 15 months - Debanded Feb 07
Am I Enjoying It? "Hell Yes!"
fins
#6 Post by fins »
My wire or band on my hawley is currently LOWER than the position of the archwire. It wasn't always this low but my ortho is doing something funky with it to move the teeth I think.
fins
