Can i drink soda with my hawley/essix in?
I just got my retainers today, essix on top and hawley on bottom, would it be best for me to take them off every time i drink soda? Probably should'nt be an issue, just double checking
I don't know the official answer to this, but I wouldn't drink anything that you wouldn't soak your retainer in. Also, the sugar from the soda may not wash down easily resulting in cavities...especially with the Essix.
Not sure...just my 2 cents. I suppose using a straw would be the safest way to go if you can't take them out. And retainers or not, it's always best to rinse with water afterward.
Upper Ceramic: 8/13/04
Lower Metal: 01/13/05
Removed: 4/19/07 (finally!)
Retainers:
Upper Clear Hawley
Lower fixed & Essix
Lower fixed removed 7/06/07 (due to a small space). Lower Fuschia Hawley 7/18/07
www.lynnhowell.com
Retainers:
Upper Clear Hawley
Lower fixed & Essix
www.lynnhowell.com
I drink non-sugared drinks with my hawleys in but I wouldn't drink soda because of the "plaque" risk. As for the essix, get use to taking them out because one day you will accidentally forget they are in and drink HOT liquids (a big no-no with Essix).
Top Braces June 2004
Bottom Braces November 2004
Debanded January 2007
