Hi guys! I think I'm getting close to retainer time. My ortho said something about a bonded lower retainer for sure and maybe a bonded retainer for just my top two front teeth. Is that strange - to have a bonded upper on only two teeth? I wonder if I ask him for a different retainer option if he will go for it?
My teeth!
Upper ceramic and lower metal braces
Round #2 - Had braces as a teen for 4 years!
Treatment time: 14 months
Braces on: July 19th, 2006
Bottom braces off: August 29th, 2007
Top braces off: September 19th, 2007
BLWR on bottom and Essix on top!
Jennielee - Nope I had no gap between my two front teeth. They were actually pretty perfect but the way the ortho placed the brackets caused my right front tooth to move up into my gumline and tip inward. They finally took that bracket off and put another one on in a different spot and eventually things went back to normal. Yeah, so, I don't know....
I have an upper bonded retainer- due to a gap in between my front teeth pre-braces. But the wire is across 4 teeth- two front ones, and the laterals beside them.
The orthodontist said- 'this will ensure the teeth dont move anywhere' and that was very comforting!
