I had a gap and an overbite, and my otho said I needed braces for 18 months. I got my uppers and lowers on Nov. 2, 2005. And after 20 months they are gone. I got my uppers off July 20th, I got my upper essix on July 27th,and my lowers came off and I got my bonded lower retainer on July 31st.
Your teeth look great! Congratulations on your new smile!
Spacers: 1/26/05; 2/6/06; 3/15/06; 4/24/06
4 First Bicuspids removed: 2/2005
Metal Braces, top and bottom: 3/1/05; Debanded 7/26/07
Hawley retainers top and bottom
Thanks Dimples,mrsphase74,kelly12300,alexa,Meryaten, and KK!
Bellita: I did have a gap inbetween my two front teeth, it started to look smaller once I got power chains. I had them for 16 of the 20 months I had braces.
Thanks Everyone!
I went back to the ortho on Wensday for a retainer check. I sat in the waiting room for about 10 minutes then they called me back. So I saw in the chair and told me to put in my retainer and I wated for the ortho to come see me. About 3-5 minutes later the othro came over looked at my teeth then he filed inbetween my two front bottom teeth. So he said that I need to come back in 2 months for impressions. I sure hope I dont have to get braces again. Next appointment: November 27th.
Does anyone have any idea how much bleaching trys would cost or any good teeth whiteing products or systems?
one question though: did you ask to get your top braces off before your lower?like your dentist..cause im wondering if i can do that too, but im a little scared to ask:P theyve only been fixing the lower teeth, because my problem now is the bite...ill ask next time i think, if theyre still not doing anything about my top ones..you see i have to go to an other clinic to get the braces OFF..he only adjusts them where i usually go...he has a lot of patients:P
regulering17 my ortho only fixes bonded retainers for bottom teeth. And it took 2 weeks for them to make mine so they kept my braces on longer than my uppers.
