Reflux happening with Retainer
ddondero
#1 Post by ddondero »
I just got my braces off 2 weeks ago. I keep waking up at night with sever reflux and vomiting. Anyone else have this happen?
alexa
#2 Post by alexa »
Nope..I haven't had this problem. :(
Are you sure the problems are directly related to the retainer? Are you gagging on it?
I know you posted this a few days ago...but if it hasn't gotten better, I would certainly check with your ortho if you're positive it's the retainer that's causing the problem.
Spacers: 1/26/05; 2/6/06; 3/15/06; 4/24/06
4 First Bicuspids removed: 2/2005
Metal Braces, top and bottom: 3/1/05; Debanded 7/26/07
Hawley retainers top and bottom
jennielee81
#3 Post by jennielee81 »
No problem with mine and I've had it for 7 months.
I sleep quite well and only wake with a nasty taste in my mouth.
Hope it all works out for you quickly!!
Chris
#4 Post by Chris »
My mouth is so dry in the morning it feels like I have paste in there. :yuck:
P.S. Make sure you are not eating within 4 hours of going to bed...that will cause acid reflux. I find that apple cider vinegar is good for that too.
Top Braces June 2004
Bottom Braces November 2004
Debanded January 2007
