How does a lower bonded retainer feel for the tongue?
I am considering strongly the bonded retainers. But I notice my tongue right now (still braced) rests on the back of my lower teeth. How does this feel if there is a bonded metal retainer there?
- jennielee81
I definately feel it, but it's not a bother. My tongue also rests on the backs of my lower teeth.
I don't know if everyone would feel this way, but it feels "normal" now. It did take a few weeks to get used to in the beginning. I had it rebonded when it broke loose last month and the new bonding actually feels better, smoother.
It is worth a try if you think you won't wear a removable retainer. I didn't have a choice so it was an easy decision for me . I like it...it works well for me.
If you get one and find that you just can live with it (after giving it a good try) it can be removed.
- jennielee81
I have not had this happen. When I was at the dentist about 8 months after having the retainer bonded, she said that I did not have any plaque buildup under or around it.
When I had to have it rebonded last month (10 months after installation) the assistant said I still had no sign of plaque.
Not saying that someone who produces a lot of plaque or someone who doesn't have extremely detailed hygiene would have the same experience. Everyone will be different.
I really don't notice my bonded retainer much anymore, only when I get a sesame see stuck in it. The only part I don't like is trying to floss around it. I can't use a threader since my bottom fronts are tight, so I loop the floss around two teeth and work it that way. The other complaint is staining around them. I brush religously, but it still stains a little around the retainer.
3M Clarity up front, rest metal--20 Jan 2006
Debraced 20 Apr 2007, 15 months total in Braces
