Keeping retainers clean
- Location: California (land of annoyingly beautiful smiles)
I got my braces off a little over a week ago. I was given a retainer and told to wear it 24/7. I was given a list of instructions but only one pertains to cleaning them "brush retainers to clean".
IMO, it doesnt seem to be doing the job. I'm brushing them whenver I brush my teeth and they still dont stay fresh very long. Also my retainer case is gross. I've even rinsed it with listerine and the freshness doesn't seem to last. =/
Is there anything I can do to get then really clean and fresh?? Right now and maybe in the long term too.
Braces off 9/19/08!!!!!!!!!!!!!!!
Both the Retainer Brite and SonicBrite products do an excellent job of keeping retainers clean. You should not brush a clear plastic Essix retainer, as it may scratch the plastic and dull the retainer over time. Meryaten is correct about being careful about solder points. If your retainer has solder, the product could cause the solder to break down over time. If your retainer doesn't have solder, then either product would be fine to use.
Both products are sold at www.dentakit.com and elsewhere on the web.
My orthodontist told me to soak my Hawleys in vinegar and if the taste bothers me to give them a quick rinse in mouthwash. However, the vinegar doesn't bother me at all. I find this method to work great. I've had them for 2 months. Whenever they are out of my mouth at home, they are in a little cup of white vinegar. I give them a quick brush off with a toothbrush and rinse with water.
I have Hawleys and my ortho's instructions were to either brush with toothpaste or clean with antibacterial hand soap. Soak for a half hour in one part water and one part Listerine twice a week to keep it fresh. And always use cold water because hot water can warp the plastic.
I do the brushing because for some reason, I feel like I would be "eating" soap if I used the other method.
I'm having the same problem. My retainer is the clear one and goes up to the roof of my mouth, and when I take it out in the morning, it STINKS (like bad morning breath). After I eat I brush or rinse with mouthwash, but even now, I took the retainer out, and it smelled again! They gave me some Fixodent tabs to soak in water with the retainer once a week, but I'm wondering what else I can use to keep my breath fresh (since I don't want to have to take the retainer out everytime I need a mint).
I wonder if Binaca (breath spray) would damage the retainer?
