I just got debanded 3 days ago and was given a thinner set of Essix retainers, but I'm supposed to get a thicker set in a month. So yes, I have two sets, except of the same kind.
jess214 wrote:I just got debanded 3 days ago and was given a thinner set of Essix retainers, but I'm supposed to get a thicker set in a month. So yes, I have two sets, except of the same kind.
Hi Jess214
Thanks for replying
Congrats on having your braces removed
Blue
Brace's -In-Ovations
Top Wired 2-1-05 / Bottom 10-9-06
Implants being used as anchor's where the wisdom teeth use to be.
positioner to sleep in that fits over the top of my bonded retainers, an removable upper an lower hawleys for day wear , still have a bit over two years to wear the hawleys , i was told being i had such a long treatment an tmj probs full 24/7 retainer wear was needed
I have both essix and hawley. I like my hawley upper and my essix lower at night for the most comfort. The essix does not last as long though and I've been through a few because of them cracking. I think the hawley will last 10 years or longer while the essix a year or two. My ortho warned me of that.
The only problem I see with having both is if the ortho "tweaks" the hawley to make any adjustments to your teeth. If you go back to the essix mold, you would see any adjustment progress.
Top Braces June 2004
Bottom Braces November 2004
Debanded January 2007
I didn't think of this. Hopefully I won't need any tweaking but
good info and something to think about.
Thanks for all the replies everyone
Blue
BracedSurgeryStudent wrote:As far as I know nope and my ortho checked for me really fast, but I haven't gone for a legit cleaning so idk.
yep looks like the ole OVERJET club is still around , still wearing bonded retainers , with hawley's over the bonded, told i'll be doing it for life , i'm ok with it just no more wires and brackets please
Hey retainerjoe glad to see you're still around too I got my braces off last month but I was kind of waiting to get my before pictures from my orthodontist for comparison, but I figured I could share this one
BracedSurgeryStudent wrote:Hey retainerjoe glad to see you're still around too I got my braces off last month but I was kind of waiting to get my before pictures from my orthodontist for comparison, but I figured I could share this one
things look great , doesn't it fell nice to have them off did you get both bonded and removable hawleys
