Hi
I currently have Invisalign braces. Just wondering if people generally need to keep going to their orthos for long after finishing braces? Is it just a case of getting you retainers and then you're finished with appointments? Or do people usually have to keep going back for a while to make sure teeth are being retained?
Thanks
Follow up appointments after braces
![Image](http://tickers.TickerFactory.com/ezt/d/4;10719;2/st/20100217/e/I+finish+refinements/dt/5/k/91f6/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10731;405/st/20100531/e/I+go+travelling+the+world/dt/5/k/7aea/event.png)
Started Invisalign in October 2008 with 26U/14L
Started refinements Dec 2009 with 4U/5L
