And I'm quite scared actually.
What should I expect?
Okay, so tomorrow I get debanded
Yes, I look froward to my orthodontist appointments
The ortho comes at you with pliers and RIPS the brackets off your teeth!!!!
Just JOKING!!!!! You will be fine. There is minimal discomfort, but there IS a little tugging to get the brackets off. Once the brackets are off, the ortho will smooth down your teeth where the bonding was.
Congrats on coming to the end of your journey!!!!!!
