Bonding
Steph in Sac
Bonding
#1 Post by Steph in Sac »
(Can I ask this here??)
I am going to get a peg lateral tooth bonded (the other one is crowned--which I am replacing). Have you had a front tooth bonded? Does it look real? Do you have any pros or cons to share?
Thanks!
TumbleDryLow
#2 Post by TumbleDryLow »
I can't speak from my own personal experience, but I just learned that a friend of mine whom I've know for about 6 years has one of her front teeth bonded. I had no idea. It looks completely natural. Apparently the only downside is that the bonding can darken over time and needs to be redone. My friend claimed hers was ready for a re-do, but honestly I couldn't see any discoloration at all.
