Can Hawley retainers be loosened up?
When I first got retainers I complained to my orthodontist that they were too loose (really dumb thing to do, you live you learn) so he tightened them up, at first I didn't notice anything different, but now they are starting to give a slight pain from the tightness, can they be loosened up again?
- TumbleDryLow
Re: Can Hawley retainers be loosened up?
I don't have Hawley's but I assume that if he tightened them, they can be loosened.
I will say that my retainers (Essex) still make my teeth a bit sore when I first put them on at the end of the day, although the soreness is usually very short lived--like maybe 5-10 min.
thanks, i guess i'll give him a call
I would think they can be loosened, but after you wear them as much as possible for a week you should have no more pain. I wear my hawleys 24/7 and when they get tightened t they hurt for a bit but with no time at all, you should be all good:)
