Essix retainer molds
GiverSSJ
#1 Post by GiverSSJ »
Are Essix retainers always done after debracing while Hawleys are done before the debracing?
Labguy
Re: Essix retainer molds
#2 Post by Labguy »
No, it is either/or for both. It depends on your doctor's preference and how they go about finishing treatment. There is no right or wrong way to go about it.
GiverSSJ
#3 Post by GiverSSJ »
Okay. Thank you for your reply. The reason why I am asking is because I got molds on Thursday for retainers with the braces still on, and she originally wanted to give me Hawley retainers. However, I had those as a teenager to correct some crowding in the front teeth and had problems with them so I called her up and told her I wanted both Essix on top and bottom and the permanent retainers on top and bottom. Which one would I be getting first most likely?
Jethro
#4 Post by Jethro »
My permanent retainers were applied just prior to the braces being removed. Molds were then taken for the Essix/Hawley retainers. I was able to get the Essix retainer later that same day since my ortho makes them in the office. I picked up my Hawley about a week later.
GiverSSJ
#5 Post by GiverSSJ »
How long does it take permament retainers to be made?
