How long does it take for molar band spaces to close?
I'm 5 months into wearing my retainers and all but one molar still has spacing (upper left) that results in food getting stuck in-between. Is it still common to have the spacing close to six months of wearing retainers, if so how long does it usually take to have the spacing close up? Thank you!
- BraceFace2o1o
Re: How long does it take for molar band spaces to close?
Good question, I have wondered this too. And does anyone know how these small gaps close, if at all? I mean, do the molars shift towards the premolars or?
Molars naturally want to move to the front of the mouth, in time they would probably fill the gaps without braces.
I was told this is why people with big/too many teeth in a small mouth cause crowding at the front because of the pressure from the back teeth wanting to move forward.
Brace Date: 14th April 2011
- BraceFace2o1o
Oh that is interesting! I never knew that. Thanks kennyandrew85kennyandrew85 wrote:Molars naturally want to move to the front of the mouth, in time they would probably fill the gaps without braces.
interesting...
i will wait for other answer..
if we use Hawler retainer, then it will be impossible for them to close, right? (Because the hook are put on the molar)
