Retainer and Gagging
So I got debraced yesterday and my bottom retainer (Hawley) is making me gag everytime I try to talk and it is hurting the right bottom under side of my tongue. If I want to talk at work without gagging I have to take it out. Is this normal or will it just take time?
Sentenced to 24 months
Upper & lower Metals
Braced on 8/23/2010
Debraced 7/23/12
Braced on 8/23/2010
Debraced 7/23/12
Re: Retainer and Gagging
It shouldn't be hurting your tongue. Go back and get it adjusted otherwise you are much more likely to just stop wearing it and then your teeth will move.
Went back and they cut a wire off and shaved some of the acrylic off. It's doing much better. Now if the lisp will just go away
Braced on 8/23/2010
Debraced 7/23/12
Braced on 8/23/2010
Debraced 7/23/12
The lisp will suddenly go away without you realising. I was debraced a month ago and have upper and lower hawley retainers for full time wear. The first three weeks I cursed them constantly. Then today I realised they haven't bothered me for a week and I can talk properly. Hang in there!
