Retainer question
milo456
Retainer question
#1 Post by milo456 »
I havnt worn my retainer in a little over a year, will it be ok if I just start wearing it again? My teeth have shifted just a little bit, do I need to go to the orthodontist to get it adjusted or can I just wear it?
Jethro
Re: Retainer question
#2 Post by Jethro »
If it still fits, you should be able to start wearing it again. You may have some sensitivity/soreness for a few days, but I would wear it continuously until that subsides. After that, you'll probably want to wear it a few nights a week to keep things in place.
If it no longer fits, you'll need to have the ortho adjust it. Good luck.
BraceFace2115
#3 Post by BraceFace2115 »
How did you get on? I'm in the same position as you. Did wearing the retainer work?
