It's been 7.5 years since I had my braces off (and 7.5 years since I logged onto this board... can't believe I remembered name and password).
I wear my Hawley retainer faithfully, almost nightly. There has been a gradual shift of my upper teeth such that I'm beginning to become unhappy with my smile.
I have consulted with my dentist, who recommended Invisalign and did quite a hard sell. But I remembered today that I still have my positioner, which I haven't worn since the immediate brace-free period. Can wearing the positioner on a very regular basis (when I'm at home, at night) re-align my teeth?
I'm going to try it, but I wondered if anyone had experience in the matter. If this works, I'm going to find an orthodontist to make some other sort of retainer- there's no way the Hawley could prevent the shifting my teeth are doing....
Thanks in advance for any advice.
Using Positioner to Fix shifting teeth 7.5 years post-braces
Damon 3's 5/22/05
Unbraced 10/2/06
Permanant bonded retainer on bottom, bite positioner, and Hawley retainer at night...
Click www to see pics!
Unbraced 10/2/06
Re: Using Positioner to Fix shifting teeth 7.5 years post-br
Update: The positioner appears to be working after 12 hours of use. There is a slight change already! I can commit to 3 hours a day, often more, of wearing this positioner... so I will. I suppose I should take some before/after photos too.
The one issue is that it's wreaking havoc on my gums.
Damon 3's 5/22/05
Unbraced 10/2/06
Unbraced 10/2/06
are you done with your Hawley? Do you not think it worked?
- phasesofbeauty
Did this work? I have relapsed teeth as well and I am curious...
