Flossing permanent retainer
Rickrolled
#1 Post by Rickrolled »
When I got my braces off, my ortho glued permanent retainers to each tooth on my upper and lower 6 as well as 2 removable. Lol at least I know my teeth are going nowhere.
The only trouble is is that is that I can't floss it. All the tutorials band such are no use even with super floss! The issue is it that I can't floss from the front as my teeth are so tight together (after sandpapering) and the retainer prevents the teeth from allowing a space for the floss to pass through and going in from the back is not an option (for the upper at least).
Are there any other options/ things I should do? I may buy a treader in the future.
Thanks
EmilyTravels
Re: Flossing permanent retainer
#2 Post by EmilyTravels »
Yeah, I'd recommend floss threaders by Oral B. They will go through really tight spaces. I also have a permanent bottom retainer, and these threaders work the best.
Speck
#3 Post by Speck »
I agree with Emily and personally use them on a daily basis.
-Andy
Jethro
#4 Post by Jethro »
Totally agree. These are the only things that allow you to floss efficiently when you have bonded retainers. I checked the box and it says Oral B Glide Threadder Floss (as opposed to floss threaders which are something different). I buy them at a local pharmacy/drug store but you can also find them online.
Congrats on getting your braces off!
All the Best,
Jethro
Braceface2015
#5 Post by Braceface2015 »
When you floss around your permanent retainer, do you also floss the retainer itself? I often can’t tell if there’s actually food stuck or if it’s just glue
djspeece
#6 Post by djspeece »
Braceface, you should realize the posts you are responding to are very old, and you may not see any responses.
