![wink :wink:](./images/smilies/wink.gif)
P.S. Checkout was a breeze, thanks.
KK wrote:Great to hear from you again Tom!
I've read the above info many times over the past week ... but it still doesn't explain why in your email to me you wrote ...I don't see why the one type that 'snaps on and off' your sink faucet is the type you've said has been designed for people with braces. This is the question I want answered ... why one model over the otherI designed the QuickPik with cleaning braces in mind. It is also a very dependable oral irrigator for gum disease.![]()
I really want to buy one ... but I'm still not sure which one ... coz I'm confused on this issue. It's a big issue buying products from overseas, coz not only do we have to deal with exchange rates, but also charges for using overseas currency ... so I want to be sure that what I buy is what I will get the most use out of, while in braces and after these foreign objects have been removed from my teeth.
Hope I'm making sense!
Ok ... so does this mean that the QuickPik is kinda portableBy that I mean is it that easy to 'snap on and snap off', so that I can take it on holiday with me etc? My holidays often involve travelling overseas ... so this one really interests me.
Apart frm the QuickPik's ability to 'snap on and snap off', are there any other differences between the two models? Also can the QuickPik be left 'snapped on', if you're happy with leaving it on one tap?
I have spent a lot of time on www.oralbreeze.com since our correspondence ... but now I need some of the 'nuts and bolt' questions sorted. This is probably a great place to do it, as it's a bit like advertising, but hopefully Lynn won't mind, as I'm really keen to buy one of your machines ... I'm just not sure which one!
Thanks in advance Tom!
Ruby Tuesday wrote:Hi! I have been following this topic with a lot of interest as I would love to order one, but want to make sure I make the right choice.
I live in an older house and have separate hot/cold taps - not one tap that automatically mixes both hot and cold water so you can have warm water. Do you think it would be okay to just use cold tap water? Would this hurt your teeth, or make them sensitive??
Thanks!
