I searched but didn't find an answer to this particular question. Someone else had mentioned this problem though. I bought just the basic Crest Whitestrips that you have to use for 2 weeks. The problem is they slide around on my teeth ALOT! So much so that I feel I am wasting my time! I try to do it when I am sure I won't be talking so that it is less likely for them to move but it doesn't help. Any tips for getting them to stay in place?
I've used Crest White Strips before- the best thing I found to do is to make sure your teeth are dry before putting the strips on- rubbing your teeth with a towel works well.
HTH!
