I just tried that Dentyl ph mouthwash which has 2 different things in the bottle that you shake together to produce an emulsion, and then use.
It supposedly makes all the gunk and bacteria in your mouth clump together and it is then dyed by the colouring agent so you can see it in the sink when you spit. Apparently one of the substances is oil-based which somehow makes the bacteria clump together as a lot of oral bacteria are water-resistant (makes sense I guess)
It does seem to work well and leaves my mouth feeling nice and fresh for a long while, and although the first time I used it I spat out loads of "gunk" on subsequent uses there hasn't been as much. So maybe that means it's doing its thing.
Dentyl PH mouthwash (two-phase)
This is the only mouthwash I have ever used. I bought it for my daughter as she got her brace before me and she likes cherry flavour, that's the reason we bought it as she doesn't like minty things. So when I got my brace I started using it and it seems good, although I admit I have nothing to compare it too. The gunky bits left over I clean with my interdental brushes. I'm happy with it at any rate.
Brace On 10th November 2006
I had to give up using this excellent mouthwash when i had my braces put on! i found the green stuff just got everywhere and i ended up having to brush all over again. so gave that up very quickly haha
i now use colgate floride mouthwash which is good but you dont see the evidence in the sink!
Amy x
Amy x
I just Googled "Dentyl PH braces" and of course I ended up back at my favourite site. To resurrect this old topic - I purchased this yesterday and was shocked to see my wires covered in luminous green mess! I guess that's the stuff you're supposed to see in the sink. Having read these posts I'll stick with it (until it runs out!) and brush off the mess - providing it isn't in any way damaging to my brace...? Interestingly it says avoid contact with plastic (despite the plastic bottle) so I had concerns about ligs.
It's all gone a bit dental...
