Is it ok to use mouthwash w/alcohol?
jadestar
#1 Post by jadestar »
I just bought ACT Restoring mouthwash and realized it has alcohol. Is it safe to use or should I only use mouthwash w/o alcohol?
Snowglobe32
#2 Post by Snowglobe32 »
I use Act Total Care, it was recommended by the ortho. It has flouride, and hardens the enamel. I like it so far, I have only had my braces for 5 weeks.
I do use Listerine mouthwash after lunch at work, so far no issues with that either.
rhxy
#3 Post by rhxy »
I now use Colgate Plax (Sensitive) as it doesn't contain alcohol. =)
Chicagogal
#4 Post by Chicagogal »
I actually PREFER the ones with alcohol during braces because I feel it washes cleaner. the dyes in the ones without alcohol can stick to ceramic brackets. the first time i used crest prohealth no alcohol i had a bright blue mouth and almsot FREAKED out. i scrubbed it off, but wont be using again.
Update: 4-2013 Back in Brackets :(
lower braces: 3/2/10
hyrax palate expander: 3/29/10
upper braces: est. 6/2010 (8/6/10 actual)
bone plate surgery: 1/2011 actual
bone plate removal: 7/2011 actual
Debracing: 10-25-11 ACTUAL!!! advanced hawley retainer
Rebracing: 4-3-13...front teeth rotated #2s lifted.
