What type of toothpaste do you use?
Sorry if there's a bazillion threads like this, most I saw recently were questions about specific types.
I'm about to start treatment, and heard it may be good to use a sensative teeth type beforehand. Any opinions?
In any case -- what kind do you use? Do you use a few different kinds depending on anything?
Thank!
Thank!
I didn't use any special toothpaste right before treatment, but I am using Sensodyne right now to hopefully help with my upcoming debanding. My teeth tend to be cold-sensitive on the top, so I hope using the Sensodyne for a few weeks will help when the time comes.
However, during treatment I used Colgate Total. Make sure it doesn't have whitening otherwise you will have whiter teeth AROUND the area where the brackets were when you get debanded. Unless you're using Invisalign or iBraces, of course.
Good luck with your treatment!
Braced Jan. 31, 2008
Sentenced to 24 months
Debraced Jan. 14, 2010!
Now wearing Essix retainer on top 24/7 with bonded lower
I use Sensodyne ProNamel at night, not because of sensitivity issues but because the hygeniest recommended it. It strengthens your enamel, so they claim. I also use Colgate Total. I have always loved this toothpaste, it has a great taste and the clean feeling last quite a while. They have a new kind that strenghtens enamel also.
I also use ACT Total Mouthwash and Listerine. They both have types that are good for brace users. Strenghtens enamel, prevents cavaties, plaque...etc.
I actually prefer Colgate Total to the Sensodyne, not only for taste but price also.
I use/used Colgate Total too.
I tried Sensodyne before debanding because of cold sensitivite too, TXmommy. It didn't help a bit in my case but you might have better luck. If not, be sure to tell whoever is removing your braces that you have a cold sensitivity issue. There are things they can do to reduce the constant blast of cold air. Rolls of gauze over the gumline made a world of difference for me.
BTW BracketRacket, the best thing you can go for post-bracing discomfort is CHEW. The longer you baby your sore mouth the longer the pain will last. So, you might want to have some semi-soft foods that require a bit of chewing on hand.
Fully braced 9-02-08
Braces off 9-21-09
Braces off 9-21-09
Thanks for the advice, Lela!Lela wrote:I use/used Colgate Total too.
I use Sensodyne ProNamel, as well. I think it's important to use toothpaste that is gentle. For some reason, braces make my teeth more sensitive. But I also have sensitive teeth to begin with. Tom's of Maine is a really good one, too.Snowglobe32 wrote:I use Sensodyne ProNamel at night, not because of sensitivity issues but because the hygeniest recommended it. It strengthens your enamel, so they claim. I also use Colgate Total. I have always loved this toothpaste, it has a great taste and the clean feeling last quite a while. They have a new kind that strenghtens enamel also.
I'm out of braces but honestly, I just buy the toothpaste that's on sale! As long as its a known brand, like crest or colgate or aquafresh, they're all the same, IMO. As for the whitening toothpastes, I think they don't really whiten teeth, I know some people that use these and still have very yellow teeth.. If you want white teeth, get the white strips they work awesome and there not expensive, I like them so much I could be really good at selling them, LOL!
ariel - try some isotonic toothpaste! It's great. There's a couple of brands that do it but I tend to get Aquafresh as it's less expensive than the others.
Re whitening toothpastes I used to think they didn't do anything but there's a colgate one which dental hygienist said some clients really liked. I had bought some and used a while back but forgot all about it. Yesterday I was looking in the mirror and thought oh my teeth look all sparkly, then realised I had used that toothpaste because I was in a different bathroom without the isotonic toothpaste in it. Seriously, that was just a one time. It's the one with white and silver packaging (not total care etc)
I'm going to try these whitening strips though!
