crest whitening strips before braces
I'm getting braces in about 4-5 weeks time. Can I usea few crest white strips (classic) before my bracaes go on? Or are there certain reasons why I shouldn't do it? If I get any irritation or pain at all I will stop immediately. My teeth are not really white and since I'm getting lingual braces I will see my teeth everyday eventhough I'm braced. Can I use it for a few days and then have like 3 weeks to rest my teeth before my braces go on, or is this a bad idea? Any thoughts? They are not super yellow so I'm only going to use the whole package.
Re: crest whitening strips before braces
I'm NOT going to use the whole package!s00102 wrote:I'm getting braces in about 4-5 weeks time. Can I usea few crest white strips (classic) before my bracaes go on? Or are there certain reasons why I shouldn't do it? If I get any irritation or pain at all I will stop immediately. My teeth are not really white and since I'm getting lingual braces I will see my teeth everyday eventhough I'm braced. Can I use it for a few days and then have like 3 weeks to rest my teeth before my braces go on, or is this a bad idea? Any thoughts? They are not super yellow so I'm only going to use the whole package.
You can use them. I used them before i got my braces, and they do burn the gums a little, but thats kinda normal. You should give yourself two weeks of non use before the braces. So you have 2 weeks to use them, thats pretty good. You can do two sessions a day from what i remember, so you may be able to use the whole box. I'd suggest getting some toothepaste for sensitivity....your teeth do get a little sensitive from strips.
