My question is....every time I use it, I spray water all over the bathroom (the mirror, the sink, my face, etc.)
My waterpik comes with a 2 year warrantee...wouldn't the motor dying be covered under the mfg warrantee? Just thinking they should be paying for any shipping charges on that. If this is going to be the case, I will return mine and have my hubby spray my head down with the hose at night...at the rate I am going with the water all over the bathroom, the result should be just about the same anyway and definitely cheaper/less stress, etc.!!!!glowstix wrote:be prepared to get a new waterpik every 2-3 months since the motor dies no matter what you do. good concept, but product design needed a bit more work. the manufacturers are pretty good about getting the new unit out to you but it gets tiresome after a while having to keep paying for shipping then having to wait while the new unit comes..probably better off without it. i've got like 3-4 months left in braces so i guess i have one more to go..
