Cleaning waterpik
Fixmygrill
Cleaning waterpik
#1 Post by Fixmygrill »
Does anyone have any suggestions about cleaning the inside of the waterpik? I just got one and have ridiculously hard water at my house that will probably clog it up at some point.
Thanks!
bbsadmin
Re: Cleaning waterpik
#2 Post by bbsadmin »
Maybe white vinegar?
I would contact the company and ask them.
It might be a good idea perhaps for you to use distilled water inside the device instead of tap water. That way it won't get gooked up with minerals.
ashesgap
#3 Post by ashesgap »
Just like your coffee pot. Run the machine with vinegar, let the vinegar sit for 15 minutes, run again and then empty and rinse with water. In New Mexico I had to do that every 3 months.
29 years old
2-18-10 baby canine pulled
3-15-10 got braces
12-22-11 Moving-SO EXCITED!!
1-2-12 Meet new Ortho
4-9-12 Deband!
kellyb
#4 Post by kellyb »
thanks for the tip. i will definitely try this. i have only been using my waterpik for about 3 weeks but sooner or later it will need a cleaning.
In braces 07/01/2012 - 29/06/2013
spacey8008
#5 Post by spacey8008 »
[quote=Fixmygrill post_id=397600 time=1334539838 user_id=19176]
Thanks!
[/quote]
For your question, I suggest you use [url=http://www.SPAM SPAM SPAM SPAM SPAM SPAM SPAM SPAM.com/]water flosser[/url].
Speck
#6 Post by Speck »
Very hard water outta the faucet here. I keep a gallon of distilled water under the sink and run a small amount of it through the unit after every use. Periodically, I'll put a small amount of 12% chlorine solution in the reservoir along with the distilled water.
-Andy
SDFD TSchott
#7 Post by SDFD TSchott »
I personally use distilled water instead of tap water in my water-pik...
Adjustment Sept 14th, 2018
Braces off April 02, 2008
DeSnek
#8 Post by DeSnek »
I run a mix of vinegar and peroxide through mine periodically!
