My ortho tech gave me some of these to cover a large gap with a wire.
That didn't really bother me. But today I got my lowers, and they are metal, and so rough they were tearing up my lip! I tried this and it is SO COMFORTABLE! It is a clear vinyl strip with a lip top and bottom, and it covers the brackets and wire! You cut to length. It maks it SMOOTH again. You can wear it only at night, but it doesn't look that bad for day wear, and take it off to eat. I'm not sure about drinking anything other than water, b/c it would probably seep into it and stay there. Has anybody else seen these?
I am new so this may not be news to anybody else, but they sure help!
I've seen this product and have thought of carrying it.
There are two types: one with little ridges that fit into the brackets, and one that is just smooth and fits over brackets. They are usually made of silicone or smooth plastic and cover the brackets entirely (from one end of the arch to the other).
Here are a couple of products that are similar to what you describe:
It is called "Comfort Cover for Braces". No manufacturer is on the package.
I have a photo, but don't know how to post it! It is from my digital, and saved as JPEG. If you can guide me through it, I'll be glad to show you.
It looks like the smooth king, with a channel. Sort of like the "morganbumber" Lynn's link showed. Two strips about 6 inches long in a tube, and clear. It is so comfortable, I defintely recommend it to be added to the Denta-Kit or available separately.
Wish I could show you!
I have tried the morgan bumpers. They looked like a great product but i just could not keep them on the braces. I have a few strips left, if anyone would like to try one - I would be happy to send you a strip to try before you buy. They are clear. Just let me know.
I wish i could find something that I could use on my braces. Wax is ok but its gets to be a pain applying then reapplying.
does anyone think these could be of any use with lingual braces? Perhaps by creating a slightly more uniform surface, it would be easier to speak since the main problem seems to be all the different surfaces on the back of your teeth that create a general airy sound and keep you from pronouncing 'S's.
Just updating information here. DentaKit.com now carries Comfort Covers. I don't know if you can use them with lingual braces -- the company that makes them offers no suggestions in this regard. However, I don't see why you can't use them with linguals -- after all, a bracket is a bracket. Before you buy them for lingual braces, you may want to ask your orthodontist.
