hi im new i have a messed up midline and braces.Are there different ways to fix it? Will i get rubber bands across my mouth or just one band on one side?
im soooo confused plz help thx
midline correction!
Re: midline correction!
I had one from my canine to the rear bottom mollar. Keep an eye on it though because my front teeth are a little bit crooked now. I'm pretty sure it was from the elastic pulling.
I got a lot of correction with just braces, but two months ago I had to start wearing a rubber band on the opposite side of my crossbite. The midline is now straight.
