Oral B Pulsar- You have to try it!
You use it like a manual brush but it has a little button on it to make it vibrate at the same time. It also has these little tabs on it to help get food out. I used it and it made my teeth feel SO clean!
Debanded on March 23rd, 2007
<img></a>
~Sara~
<img></a>
~Sara~
I saw one at my local Target, but was wondering if it really works that well? It was about $4.50, I quess I'll give it a go!hannah164 wrote:Just curious, how much did it cost and wear did you find it? It sounds pretty cool.
THanks,
-Hannah
Spacers: Aug. 22, 2005
1 Wisdom Extraction: Aug. 27, 2005
Braced: Sept. 8, 2005
4 First Bicuspids Extraction: Sept. 9, 2005
- jennielee81
That's the toothbrush my 16 year old daughter chose for her "after braces removal prize". Nothing's too good for my kids
She really likes it!
Loved it!
Hello All,
I got one just yesterday and I just love it...I will be getting braced next week and I am preparing by getting all of the do-dads that I will need.
I think it makes my teeth feel so clean! I just can't afford the more expensive type brushes and this is wonderful!
Enjoy life to the fullest and take chances! :0)
ahh soo cleannn
omg this made my teeth feel soo clean...the backs of your teeth are SO smooth, and you there's NOTHING caught between your teeth! i got it at target for 5.79 or something, it was so cheap! plus on the back it says it's as effective as flossing. feels great.
I went from the Oral B CrossAction Power toothbrush (-click-) to the Pulsar and I like the Pulsar toothbrush SO much better. My teeth feel a lot cleaner.
Four Wisdom Teeth Extracted: January 2000
Lower First Bicuspids Extracted: Nov. 1st, 2005
Braces on: Nov. 24th, 2005
Duration: 24 months
Duration: 24 months
