I hate flossing. I've always hated it, but I've always done it after every meal.
Now that I have braces, I hate it even more. It's necessary...you wouldn't believe the crud these stupid braces hold on to. I rinse with water three or four times after I eat something and generally brush and floss then, too. Even after rinsing, brushing and rinsing again, I still get gunk with the floss. It's so nasty.
I would say that anything that makes it even remotely easier to floss is very much worth it. That being said, the problem that you may run into is that the majority of flossers don't have the ability to go underneath the archwire, which is the only way to floss with braces (unless there's something someone knows that I don't...). I'm not sure if the Reach one has an open end to slip under the archwire or not, but you may not be able to use it with braces if it doesn't.
I've had a tremendous amount of luck with the Crest Glide Threader Floss. I can't get the other flossers thru the tight space to do two of my bottom teeth. I've tried both the Oral-B Super Floss and the GUM Floss Threaders (I was hoping to be able to use this with my regular floss as I prefer it) and neither worked for me. Hopefully once I've gained some space on my lower arch, I'll be able to use the GUM Threader and my regular floss.
