Hi all,
just some months after I discovered how wonderful Rembrandt toothpaste,
the one with baking soda in it, is, it seems to have been withdrawn from
the market. Maybe something to do with Rembrandt being moved from
the Gilette Group to Procter and Gamble, or was it the other way around.
Anyway, my favorite toothpaste can't be bought anymore. Someone of
you knows if this is true, final or only temporary ? Or maybe someone
knows a similar toothpaste with baking soda ? Thanks !
Rembrandt toothpaste ...
AWSEOME STUFF!
Baking Soda is AWESOME!!!
It can:
Check this out:
http://www.armhammer.com/basics/magic/
I guess I shoulda posted this in Off-Topic, huh?
I sound like a walking (typing) advertisement. BUT THE STUFF IS GREAT!
It can:
- deodorize trash cans and litter boxes (dump it in the litter for long term)
soften water (dump it in your bathwater to soften skin- and makes more bubbles!!)
use as/in toothpaste
put it in shampoo (once a week) to get rid of product buildup.
laundry booster
help keep your pool water clear
set in fridge to keep food smells out
sprinkle on carpet/upholstry then vacuum to remove odors
sprinkle in shoes to remove odor
antacid
face scrub
foot soak
hand cleaner when mixed w/ liquid soap (think LAVA soap)
neutralize battery acid
fire extinguisher
put in bottom of ashtrays to keep stale cigarette odors at bay
dry bath for dogs
freshen stuffed animals
use to clean almost anything (like Comet) - great for cooking surfaces where you don't want to use harsh chemicals
Check this out:
![Image](http://tickers.TickerFactory.com/ezt/d/4;10729;60/st/20050823/e/I+got+Braced%21/dt/-1/k/14a3/event.png)
![Image](http://tickers.TickerFactory.com/ezt/d/4;10722;120/st/20051116/e/Since+I+Quit+Smoking/dt/-1/k/87ed/event.png)
Re: AWSEOME STUFF!
Your cats are looking decidedly uncomfortable in the corner right now...amychelle wrote:Baking Soda is AWESOME!!!
It can:
- freshen stuffed animals
Shagers - Braced Aug 05
Lipton Mr T - finally, a tea for the real man. I pity the coffee drinkin' fool.
- HollyDontSpend
Re: AWSEOME STUFF!
I am gonna have to try that!!!amychelle wrote:Baking Soda is AWESOME!!!
I won't take a bubble bath without putting some soda in my water. It makes so many more bubbles and my skin is so much softer.
Damon 2's for 18 months, removed 11/03/05
Re: AWSEOME STUFF!
LOL!Shagers wrote:Your cats are looking decidedly uncomfortable in the corner right now...amychelle wrote:Baking Soda is AWESOME!!!
It can:
My dad really is an amature taxidermist.
