mapleleafman888 wrote:Yup today is my 1 year mark (posted a new photo)! Again, time goes by soooo fast.
Asides from your wonky tooth, as you call it, what else is left to work on? It looks like the rest of your teeth are straight.
Oh, and what went on at the last adjustment?
I had my latest adjustment last week. He walked over looked and said, well, that tooth is larger than I realized. He said he is going to make it fit, and then proceeded to file between my teeth some more. Man do I dislike that. I guess if it gets the tooth in there then it's worth it in the end.
They just re-cinched my top wire, I got a bigger wire on the bottom and that's about it.
Everything else is good as far as my bite and my top teeth are all in place. The lower is a bit misaligned now because of the turning of the crazy tooth. He said at my next adjustment he expects to take off the sliding bracket and replace it with a regular bracket to get the wonky tooth in it's correct spot. I sure hope so. It has felt like I took two giant steps backward!
Your smile looks GREAT! I know you are thrilled! I still have not asked how much longer he thinks I have. I have been waiting to ask until I See some major improvement in the wonky tooth.
