1st post!
Re: 1st post!
Do you colored elastics at the bottom? Or just the silver ones?
Re: 1st post!
Msdanyale wrote:Every time I try and post them it says the file is too large
I found if I emailed pics to myself in a smaller format from my iPhone then saved them it would automatically shrink them... or if you edit the picture on your phone first (like .. crop it etc) it usually saves smaller..
Re: 1st post!
I only have silver. Didn't want any colorsnybizzle wrote:Do you colored elastics at the bottom? Or just the silver ones?
Re: 1st post!
Re: 1st post!
Pictures are not in order. I'm sorry! There are two from Monday morning when I got my wires changed from the 14 to an 18. I'm having a hard time uploading the rest.Msdanyale wrote:FADA6587-37A8-459A-9CBE-135E5840272B.JPGnybizzle wrote:Do you colored elastics at the bottom? Or just the silver ones?
Re: 1st post!
Hi there, I'm new to braces too
I'm 29 and have ceramic (clear) braces on upper and lowers fitted on the 26th of April, the ortho said i didn't need any extractions but I'm not so sure as there doesn't seem to be much room to move! He also said that the treatment time would be 12 months but again, I'm not so sure because I've not seen any progress yet although I can feel them moving - guess Im just being impatient
Re: 1st post!
wanna see progress dont get embarrassed!
Re: 1st post!
Hello!!! I've posted pictures. Let me know if you can see them!!minutemen123 wrote:
Re: 1st post!
Msdanyale wrote:Image-1.jpg
Your teeth are looking great so far! Good progress
Re: 1st post!
Wow great progress !!! All in the time frame of how long ?
Re: 1st post!
Thank you! I got the brackets put on March 13th, but she didn't put a wire in until April 18th so this is about six weeks in technically.Jeska0113 wrote:Wow great progress !!! All in the time frame of how long ?
Re: 1st post!
Thank you!! I cried after looking at the "before" pictures lolSteph30 wrote:Msdanyale wrote:Image-1.jpg
