Although my jargon savvy is minimal, I think you are right Eleni, and no I'm not getting implants, everything is being shifted around to close the gaps (I HOPE!) My ortho asked me what my desired outcome was and I said I quite liked having fangs on prominent display at the front of my mouth, I just wanted them all to line up beautifully, so that is what we're going for... an aesthetically balanced vampire effect
Meanwhile, my fakies which were covering my monster holes have shifted along with the teeth next to them, which is good in theory since it means my braces are definately working, but in reality it means they have shifted to the side so there is like a 2 mm gap where you can see the holes behind them. So now the end result is like when you try to cover a bad toilet smell with cheap perfume and the stench mutates into new and unheard of vileness... if you follow the analogy...
I tried to take a pic to add visual reference to my description but it doesnt really show the dilemna, I think I'll put it up anyway cause it catches me at a rather striking angle
Well tomorrow is my first adjustment, 3 weeks since I had them put on and hopefully my ortho will be able to do something about my fakie situation... I'm actually kind of looking forward to it even though it may throw my teeth back into mush food status, I'm impatient so any change is a good change!
And finally, here is the recipe for Japanese Comfort Mush courtesy of my boy (I've added a western version just in case)
2 cups cooked Japanese rice
2 cups Dashi stock
Shoyu
2 eggs
1 can chopped shellfish
It's super quick and simple, heat the dashi stock till its simmering, add the rice, and drained shellfish, cook about 5-10 minutes till mushy, beat in 2 eggs and stir for one minute, turn off the heat and add shoyu to taste. Voila, mush!
Western Version:
2 cups short grain rice
2 cups chicken stock
Soy sauce (or salt and pepper)
2 eggs
1 small can of tuna in brine
Pretty much the same method. Voila, westernized mush!
It should end up looking like an unappetizing risotto, but its very yum and full of carbs and protein to keep you going when eating is a trauma.
