Went in for my first adjustment today. I wasn't really expecting much. I figured he'd probably just either leave in the first archwire and change the ligs, or maybe put in a little bit stronger archwire. Guess it's good to go in with low expectations, because then you get surprised with good news!
My teeth are all loosened up and ready to roll. So I got new archwires (17 stainless steel...) and powerchains. Definitely wasn't expecting to start powerchains to close my extraction gaps this early. Yay!
I'd already had my colors picked out, and was just sitting there trying to decide whether to alternate or just do one on top and one on the bottom. So that solved that problem. I've got a blue powerchain from 1st molar to 1st molar on top and the same in purple on the bottom. Skipped one loop over each of the extraction gaps.
I'm definitely sore after that! Just when he was putting the archwire in, before they put on the powerchain, it felt tight on the top. So I knew it was going to be a bit of an adjustment. Things are moving around already. Before I even walked out of the office, I noticed that when I bite down, my lower incisors are hitting my uppers just a tad (not the brackets, just the teeth). So that's a bit sore. And the occlusion in my molars is all off again. The weirdest part is when I bite down on my molars, I can feel it pulling along the archwire all the way around to the incisors.
So I had chocolate ice cream for dinner. And some parmesan goldfish. I think it'll be soup tomorrow.
Okay, since I know you're only here for the stunning photography, here you go:
Hmmm.... You like how those two front teeth have traded places? I don't get it either. Ortho says it's okay, though. Minor adjustments that can be made later. I just think it's funny that the one was a little in front before, now it's the other. Maybe they're racing. (I promise I didn't mirror-image the photos, either... Check out the fillings.)
