Just a quick update.
Now have 0.16 x 0.22 niti wire in the top and 0.16 round stainless steel wire at the bottom. Things are slowly improving and alignment is slowly getting better. I have developed a slight overjet and my bottom central incisor will need some bone and gum graft done at some stage due to the bugger up the dentist caused during extraction of my central incisor. My period said I would loose the 2 teeth adjacent to the extracted tooth. Well with 4 months of stabilization the situation seems I am not going to loose any teeth although like I said some grafts need to be done. I have also developed some dark triangles but these will be addressed with some ipr which will also adress the slight overjet. Otherwise I am on track and praying it all works out.
Below will be updated pictures.
32 years old and 1 month braced.
Re: 32 years old and 1 month braced.
Before and two current picture
2 more pics before and now
