So in Dec 2009 I decided that the time was right, financially and because I'll be returning to uni it wont be much of a problem image wise for me. I got seen by my ortho in February 2010 who then referred me to a periodontist to check on my oral health. I had hated my teeth for so long that I had only seen a dentist a handful of times since my teens, for wisdom teeth extraction and fillings. Fortunately I dont smoke so the damage wasnt too bad considering such neglect from me.
Periodontist was brilliant and introduced me to proper flossing (I was so bad and only flossed like once a fortnight if that!), a Braun Triumph which I have used faithfully since . I use it now with 3 heads, ortho, standard and interdental on different tooth areas.
The only concern is that I may need a frenectomy for the maxillary labial frenum, precision, and root coverage procedures for any gingivial recession.
So with that news the ortho began his first stages treatment - xrays, photos, moulds. This went problem free and I got braced on the 18th May 2010.
Went home, all good, then...that evening ouch, pain, ouch, pain...felt so yucky that I went to bed early with some nurofen (pain killer). The next few days were much better (it does get better!), and I couldnt stop looking at my grills at every chance I got.
Teeth cleaning from start to finish took 30 minutes for the first 2 weeks but now at week 3 Im down to 20 minutes. Its the flossing that takes up time but its getting easier. The waterpik that many of you use is available here in Auckland but my goodness its like nearly 4 times what it costs in the USA. I think I'll just soilder on with my floss.
My weight dropped off too - I've lost 5 kg in 3 weeks. Just goes to show what a sweet tooth I am because I cant eat the banned stuff anymore. Plus after youve done all your teeth cleaning its not worth having snacks in between main meals. Now Im eating most normal foods, just having to make them bite sized and then chew them on my molars.
So about my teeth prior to bracing. I had a tooth extraced when I was 13 due to crowding on my upper right and because the dentist thought I'd be getting braces. I have always had a slight gap (family thing) between my front 2 teeth but its got considerably wider over the years. 2mm upper midline diastema and open contacts between several teeth. Also on my right side the upper teeth sit inside the lower teeth. I have ceramic uppers and metal bottoms. I wanted damon but my ortho has a preference for his adults to at least be in upper ceramics. I think mine are ICE. Some slight staining on my clear ligs but not too noticiable. My ortho feels that I'll be braced for 18 - 24 months.
Hes also put these blue build-ups on my molars that Ive managed to get used to.
I've put pics up of my teeth before bracing - my next ortho appointment is in 2 weeks time.
![Image](http://img820.imageshack.us/img820/677/049b.th.jpg)
URL=http://img811.imageshack.us/i/046s.jpg/]
![Image](http://img811.imageshack.us/img811/6048/046s.th.jpg)
URL=http://img692.imageshack.us/i/048tg.jpg/]
![Image](http://img692.imageshack.us/img692/7724/048tg.th.jpg)
URL=http://img821.imageshack.us/i/044.jpg/]
![Image](http://img821.imageshack.us/img821/7611/044.th.jpg)
URL=http://img811.imageshack.us/i/050.jpg/]
![Image](http://img811.imageshack.us/img811/1896/050.th.jpg)
