Deep bite correction, from Italy
concorde
#1 Post by concorde »
Hi everybody, I'm 38 years old from Italy. I have a deep bite and some teeth are not aligned.
On September 17 I started my treatment with clear braces on maxillary teeth.
After one month I've got clear brace also on the mandibular teeth and also two guides behind my 2 superior incisors. These are to correct the deep bite. Now I can't post pictures (due to forum rules), but I hope you let me able to post soon some pictures because I'd like to know your opinions.
Ciao everybody!
concorde
Re: Deep bite correction, from Italy
#2 Post by concorde »
This pictures is after 1 month of upper clear braces.
concorde
#3 Post by concorde »
On October 16 I've got also my bottom braces.
concorde
#4 Post by concorde »
It's hard with the mouth full of brackets, but the worst are these things behind the incisors. What's the name in english?
Tobilei
#5 Post by Tobilei »
Hi Concorde :mrgreen: Welcome to the board! Not sure what the things behind incisors are called. I have stock standard brackets just to move teeth. I'm sure someone else here would know though.
concorde
#6 Post by concorde »
Thanks for your welcome!
Maybe these things could be called "build ups"?
Tobilei
#7 Post by Tobilei »
If they're like a hard putty that they've put on your molars yes. My daughter has blue one's to stop her biting down as I said in my thread :) (Sorry I can't really see them in the photo).
concorde
#8 Post by concorde »
No, on my molars I've nothing. I only have these little hard balls behind the incisors!
BetsyBug
#9 Post by BetsyBug »
They are called bite turbos. I had them for about 6 months. They suck but you will get used to them :)
Elizabeth
Getting top and bottom traditional metal braces and bite turbos
correcting crowding, overbite, and TMJ on 3/6/2012
Turbos Removed 8/14/2012
Click for my story
concorde
#10 Post by concorde »
Hi Elisabeth! Thank you very much! Now I know the name of my horrible things behind the incisors: bite turbos.
Now, after almost 2 months with them I'm still not able to chew and to speak normally!
I dont know how long I will need them. I hope no more then 6 months, like you. I saw yours treatment pictures: a lor of progress!
EbonyQ
#11 Post by EbonyQ »
Welcome!
Have a deep bite myself and was supposed to get those bite turbos but I wanted to wait a little extra before putting on my lower. Because of this I did not need any molar buildups or bite turbos but they say that you will get used to them :wink:
Ciao!
p.s I worked as an Au Pair in Italy about 3 years ago, a small city outside of Milano :D
concorde
#12 Post by concorde »
Hi, thanks for your answer! Maybe it was better for me to wait more before putting the lowers in order to don't be obbliged to use bite turbos, but now I can't do nothing else... I must hope that they will be removed soon. Braces are not so bad, but turbos are awful!
I saw your story and you made a lot of progress also without them!
Ciao!
BetsyBug
#13 Post by BetsyBug »
It will get easier I promise. I was definitely ready to have them gone when it came to it, though. :)
Elizabeth
Click for my story
concorde
#14 Post by concorde »
I read a lot of stories and I saw a lot of pics on this forum and now I don't understand why I'm the only one to have metal ligatures with clear braces! :((
therampagerado
#15 Post by therampagerado »
Probably because you're early in the treatment. In time when forces weaken your orthodontist will use clear ligs for sure.
