My Braces Journey - Extraction Regret!
Stargirlxx
#1 Post by Stargirlxx »
I am 23 years old and had my first set of braces at age 17. I am currently 23, and 2 years into my second set of braces. I am 6 months post-extraction of 2 upper bicuspids. I am including photos of my journey to date:
Age 16, before braces or ANY orthodontic treatment. (I got braces a few months after this photo was taken) My concern was crowding. Braces and jaw surgery were recommended to align my face/bite better.
Age 19, braces removed. I decided against the jaw surgery since I was extremely happy with my ortho results, and I had a newborn baby. Didn't want to put myself through the potential agony of jaw surgery. I had had 2 lower wisdom teeth removed as well as a lower middle tooth.
Unfortunately, my bite was not stable and I lost my functional bite over the next 6 months. My retainer broke, and by the time it was replaced it no longer fit. I opted to be re-braced at age 21. This time the braces experience did not have the same effect as before, and I was increasingly concerned with the results. A year into braces I had NO functional bite, and my front teeth were flaring outwards. Here I am right before getting re-braced:
And here was my mouth two more years into braces, age 23:
As you can see, my results were NOT like before. My top teeth stuck out and I could no longer close my mouth! It also appears as though my arch has constricted inwards!! I was getting impatient because this time around I found that the quality of my teeth and gums were also deteriorating. Despite my oral hygiene being as good as always, regular cleanings, etc, my teeth were becoming increasingly sensitive and my gums inflamed.
The ortho said to address my "extruding" teeth, I had two options, jaw surgery, or he could extract two upper bicuspids. Not wanting to go the surgical route, I opted for the extractions, since he assured me it would only take 6 months to close the gaps and that the only potential 'negative' change would be that my upper lip wouldn't protrude as much and look a bit flatter. I figured that was better than not being able to close my mouth with my newly protruding teeth!! Sigh.
So here are my results 6 months after the 2 upper bicuspids were extracted:
Image Image
as you can see, I can close my mouth again, but I've also lost all facial support. The skin sags around the mouth area, and because of the retraction of my upper teeth, my tongue no longer fits comfortably in my mouth, my lower jaw is retracted back, which restricts my airway so I can't breath properly anymore!! In the months following extraction I began to get tmj symptoms as well. Chewing is awkward. My ortho says his "hands are tied" now unless I get jaw surgery. I don't want jaw surgery unnecessarily, and I don't want to live with my decreased quality of life and health either. I am considering going to a better qualified ortho who will expand my palate and re-open the extraction sites for implants. ARGH. And he is in California, whereas I live in BC, Canada. I have already spent nearly 8 grand and the last 6 years in ortho treatment and I hate that I'm no better off than before. Actually, my health has deteriorated as a result of this last round of poor treatment.
Funsizee
Re: My Braces Journey - Extraction Regret!
#2 Post by Funsizee »
Hi Star,
I'm so sorry to hear about your ortho experience. I was also told by my ortho that I need to extract 4 teeth but have decided to put that on hold because I am scared that I will regret it and have also read somewhere in this forum that there was a possibility of facial collapse? I'm not sure if I'm wording it correctly.
Thank you for sharing your experience and I will you luck with your next ortho.
Tobilei
#3 Post by Tobilei »
I too am sorry you're having so much trouble. Was it the same ortho who has done all this work to you? I'm glad you asked an opinion of another ortho if this is the case.
Good luck with re-opening your extraction gaps. I hope it helps to fix some of the problems created for you so far.
Stargirlxx
#4 Post by Stargirlxx »
Updating with better photos:
A photo from 2010 prior to my current set of braces:
what a NIGHTMARE! :evil:
SunshineRay
#5 Post by SunshineRay »
I'm so sorry you are going through this!
jazzyjazz
#6 Post by jazzyjazz »
sorry you had to go through that,,this worries me slighty :-/..so in total you have had 4 upper teeth removed? x
ruchel
#7 Post by ruchel »
Im sorry to hear that you are going through this - I am also from BC - I live on Vancouver Island - My orthodontist seems great but he is suggesting extractions + surgery
And my teeth look similar to yours - I am now super worried about the extractions - do you think if you had the operation you would have had the same issues - also what jaw operation do you need? I was told I'll need a BSSO
Thanks for sharing your story - good luck going forward!
