Which toothbrush is best for braces!? I have found one!
Hello all, four months into my 6 month smiles experience having tried every toothbrush available to man, I have found the ultimate one! It is a Wisdom, clean between toothbrush, it is soft but wide and does not hurt or damage gums. I still use small brush to do the finer details, but I thought I would share this one with you! If you are in the UK they are for sale in Home Bargains for only 99p!!
Re: Which toothbrush is best for braces!? I have found one!
Mine is a Sonicare electric toothbrush. Expensive but does an excellent job.
