Immediately prior to getting braces back then, I had to have eight teeth pulled (four permanent and four baby teeth). Around the age of 21, I also had my four impacted wisdom teeth pulled. Both experiences were kind of horrific, and I ended up with dry socket as a result of the wisdom teeth extractions (I remember it all too well).
Stupidly, and regretably, I was not compliant with my retainer way back then, and have a lot of crowding, especially of my lower teeth. I've been told the crowding will just continue to worsen with age (I can see it happening!) and make cleaning more and more difficult (it certainly has been, though I do take very good care of my teeth). I certainly don't like how they look. At the very least, the ortho I met with said I would have to wear a retainer indefinitely if I chose not to get braces just to keep things from worsening. That is, of course, not an acceptable option because it doesn't address the problem!
The crowding on the bottom has caused one tooth to get pushed very out of line, which is not only noticeable, but occasionally my tongue hits it and effects my speech momentarily. The crowding on the lowers has also caused my upper two front teeth to flare out (to me it seems I have buck teeth again) and look uneven, even though they are the same length. When I look at photos of just my teeth (as opposed to looking in the mirror) I can really see objectively just how uneven they are. I am really hoping having braces again can fix this. It will really help me keep things cleaner.
My teeth are generally healthy now, but I've endured two root canals in the past and have two crowns (by two different dentists). One is really ugly (half metal, half porcelain, you can see it in my pics, but it's never given me any problem) and one has come off repeatedly and I've lost count of how many times the same office has replaced it.
Next week I am having some dental work done. I have an old amalgam filling that is cracked, and another amalgam one that is worn--both will be removed and replaced with composite. I will be very happy to have the last of the mercury fillings gone from my mouth!
The ortho I have consulted with in October 2005 recommended Invisalign for me, but given everything I have read here (and on another message board), I will probably not go that route. I have moderate crowding, and I thought Invisalign is best used with only mild crowding. I am leaning towards ceramics or metal brackets. I like the idea of ceramics (but the office I went to said they make your teeth look yellow, and told me they didn't recommend them--I found that odd since ceramics are often recommended for adults) but worry about the risks when de-bonding. My head is swimming with ceramics vs. metal, self-ligation vs. not--I don't know which is better.
I have only had a consultation with one orthodontist so far, and have scheduled the study models and x-rays as well as the formal consultation for January 2, 2006, mostly because my flex spending account doesn't kick in until 2006. This last week, I received pre-authorization from my insurance company (they cover just $750 of treatment).
However, today (11/20/05) I am having doubts about this ortho, and am going to call tomorrow and schedule consultations with several other orthos. I don't know why I was in such a hurry and didn't do this already. I should know better than to just have consulted with one (that is not like me).
One doubt I have is that, even though his office tells me he is board certified, I cannot find that he listed with the two organizations I searched.
Another thing that I don't feel comfortable with is that I have already asked quite a few questions of the office staff, and they seem slightly put out by it. That bugs me for obvious reasons. I like to be informed, especially with something like this involving my teeth, the only ones I'll ever have!
Lastly, I am curious to know if the cost of treatment that I was quoted is typical for this area ($5,700-$6,200). I live in a large city so the range being at the upper end doesn't surprise me, but since I don't believe I have a complicated case, it seems high.
I did like the ortho in general, thought he was down to earth and did not feel rushed out the door by him. I was asking him about what kind of plastic Invisalign trays are made with (because of my concern about plastics leaching chemicals into the body) and he was very responsive--he got in touch with the company, found out the info, and called me personally and spoke with me for about half an hour about what he found out. I'm bugged about his staff though, and can't imagine why he is not coming up as board certified.
Reading the forums here have reminded me how important it is to get several opinions (thank you to everyone here for that!) so now I will do that. Fortunately, I haven't committed to anything with the ortho's whose report is below.
I still have so many questions! I know these need to wait until the formal consultation once the ortho has my study models and x-rays to review.
Here is an excerpt from the the letter I received from the ortho:
CHIEF CONCERNS: Crowding
DENTAL AND SKELETAL FINDINGS:
Class I
Moderate upper and lower crowding
4 bicuspids & wisdom teeth extracted
Normal overbite and overjet (this is one thing I don't understand--does it need treatment? I do feel I have an overbite and an undesirable overjet, but he doesn't give a measurement)
I also am not clear at this point how to check whether or not any ortho I go to has any complaints pending against them. I had a bad experience with a dentist once and just want to make sure that whoever I end up with, it is not someone who has had repeated complaints.
I will be calling three board certified orthos downtown tomorrow to make consultation appointments.
Here are some photos of where I am beginning (again!).
