My story begins in March of '03... I had started with the invisilign, which were so great at the beginning. My top teeth were pretty bad, but the bottoms were ok. I started off with them telling me I had 53 trays for the top, 13 for the bottom. That was fine. I had gone in when I only had 4 trays left for the top...I was so excited to be nearing the end!! The decided to take some more impressions for a mid-course. They called later and broke the bad news. 54 more on top and 8 more on the bottom!! I said, you have GOT to be kidding. But, I went along fine with it; you cant really see them anyway and by that point I was so used to them. Well, turns out they quit working altogether. So, about a month ago they put the regular braces on me.
I don't think that I would change doing the invisilign first though; I really did like them. Plus, now the process will be so quick with the regular braces, I will be done in no time! I really am amazed that after having invisilign for so long, just putting on the regular braces, my teeth have moved so much! I just turned 30 a couple of months ago, and I just wish I would have done this years ago... That's all for now. I'm looking forward to getting to know all of you and your stories!
