My goodness, I DID type in the wrong name. My apologies to you, Crookedteeth88.Crookedteeth88 wrote:Hi Tennesseeditto!
I do have a arch expander in mine. I assume you wrote that for earthgirl. But some questions to you Tennesseeditto:
1. How old are you, if I may ask (do not need to answer if you dont want to)
2. You have never worn braces before?
3. How long do you wear the IA each day?
4. Have you seen any changes?
5. If so, could you post some pictures?
Haha, I'm getting a little impatient. No change in 5 days! Or maybe it is to small to be noticable. Looking foward to my next appointment to see if he thinks my teeth has moved.
Good luck girls!
In response to your questions:
1. I am a young 62 years old.
2. I have never worn braces.
3. I wear the IAs between 20 to 22 hours each day, except on Sunday when I give myself a 6-hour respite as I cannot sing with them in my mouth.
4. Yes, I have seen definite movement, especially on the top where I have two front slightly "bucked" teeth with one rotating over the other, probably because I sucked my fingers as a small child. One of my front teeth is now perfectly straight while the rotated one is moving off the "straight" one. There is now a slight gap on the top between them that has not been there since I was a child. It IS working--hurrah!
The bottom teeth are crooked because I simply have a small mouth, hence the reason for the arch expanders. One of the four in front is also straight and the other three are moving but not as rapidly. But hey, it's been only 27 days so I am quite pleased with the progress.
I return to my dentist tomorrow for new mouth molds and evaluation.
5. Regarding the pics, I do take them every 7 days and will post them as soon as I can crop them.
By the way, I didn't see any change for the first 10 days.
Be patient and it will work.
