Every mouth is different. Let's not all get freaked out on this.....
Mine are all connected as my molars are my issue. allot of you do not have molar issues and therefor they are not connected. Talk to the doc....
ortho humour???
My lower 7s were connected after a year because one of them started drifting astray. My upper 7's are still free and I would imagine will remain so since I'm almost done with treatment. Once you get through the adjustment phase things will get easier, just give it time (hard to do I know!)
My upper 7's have been on the wire since day one, and the lowers for virtually the same time. My bite opened a bit at the front (less than 1mm I'd say), but as you know, all is now closed.joney wrote:Eek! My number 7s are on the wire and I'm starting out with an openbite, I certainly don't want it to get bigger!
Regards
Joney
Mine have brackets but my ortho predicted he'll never wire them in. But those lower back brackets drive me nuts - my gums are irritated because the bracket is the exact same size as my tooth and it barely fits on the surface... the BACK of the bracket touches my gums. I really wish they weren't bracketed.
now im even more confused
my ortho wrote a letter to my dentist regarding the work that needed to be done before banding. He said that I needed a root canal in #9 and he is referring to my front left incisor the one you labeled as #1?
I was already confused because my basic knowledge of dentistry tells me there are supposed to be 32 teeth in the mouth, if there are 4 quadrants then there are only 8 teeth in each then how is there a #9?
I realize that most dont have 32 teeth I know I have a big mouth and so dont have room for 32 teeth.
